February 21, 2017, 07:40:14 AM
62455 Posts in 4593 Topics by 380 Members
Latest Member: 93weezer
|-+  THE HEAD SHOP
| |-+  Flow Jobs to Valve jobs (Moderator: Is1BadFord)
| | |-+  GT40/GT40p valve sizes......
Pages: [1] Print
Author Topic: GT40/GT40p valve sizes......  (Read 4503 times)
302ute
Full Member
« on: April 11, 2011, 02:48:11 AM »
I have a set of GT40p heads and a set of GT40 heads. It looks as if the p heads have a smaller exh valve. I have two sets of 6000 series ferrea valves which measure 1.94 in and 1.55 exh. Is there enough material in both of these heads to take advantage of the larger intake?  And also is it beneficial to put 1.55 exh valves in the p heads?
The heads owe me nothing and the valves are brand new and were VERY cheap.
Thanks in advance.
Bad95gts
« Reply #1 on: April 11, 2011, 04:41:46 AM »
Yes they will go in. The 1.94 intake is probably more than it needs but I would use them.
Live simply, love generously, care dee ply, speak kindly, and leave the rest to God
jayh
« Reply #2 on: April 11, 2011, 05:42:02 AM »
1.94 will definately go in. Ive seen a 2.02 in dooe 351 head which is what that intake port is based off
-=OLD SCHOOL=-
65mustang393
Guest
« Reply #3 on: April 11, 2011, 05:52:46 AM »
« Last Edit: January 16, 2012, 01:09:24 PM by 65mustang393 » Logged
rmcomprandy
Sr. Member
« Reply #4 on: April 11, 2011, 07:29:46 AM »
Your valves will work fine.
Also,  I have used a 2.02" intake valve, (bowl ported of course), with a production size exhaust valve, (or a 1.500" diameter), and the clearance around the spark plug is the point to look out for.
 The big intake / small exhaust works well especially when an exhaust system needs to be used and it is cammed correctly for this.
« Last Edit: April 11, 2011, 07:35:36 AM by rmcomprandy » Logged
www.rmcompetition.com
The finest in Custom Engine Building for all venues ...!
1(586)909-1591 ... fax 1(586)771-2930
Selling Parts & Supplies from companies I use.
65mustang393
Guest
« Reply #5 on: April 11, 2011, 08:34:29 AM »
« Last Edit: January 16, 2012, 01:09:04 PM by 65mustang393 » Logged
65mustang393
Guest
« Reply #6 on: April 11, 2011, 08:44:03 AM »
« Last Edit: January 16, 2012, 01:08:30 PM by 65mustang393 » Logged
302ute
Full Member
« Reply #7 on: April 11, 2011, 02:48:59 PM »
Thanks for the replies. Is there any real benefit in running the larger intake valve even if I have already done the throats on the gt40p heads as far as I am game? In other words, same throat size just a larger valve.
jayh
« Reply #8 on: April 11, 2011, 02:59:44 PM »
the dooe's I seen were 2.02/1.50
the word on the street/general consensis is to run as much intake valve as physically possible. makes sense to me.
-=OLD SCHOOL=-
Pages: [1] Print
