TNR Forum
Welcome, Guest. Please login or register.
September 22, 2017, 03:35:14 PM
Login with username, password and session length
Search:     Advanced search
SMF - Just Installed!
62497 Posts in 4597 Topics by 383 Members
Latest Member: carbed79
Home Help Search Calendar Login Register
+  TNR Forum
|-+  TRACK SMACK
| |-+  Suspension & Rearends (Moderator: Matt Paul)
| | |-+  DragBoss: Mounting DA Rear Shocks
« previous next »
Pages: [1] Print
Author Topic: DragBoss: Mounting DA Rear Shocks  (Read 2021 times)
DragBoss
Sr. Member
Offline Offline
« on: September 10, 2015, 10:04:41 AM »
Well I have had the same Rancho shocks since Calvert used my car to make the 2 piece mono-leaf spring for Mustangs and Cougars back in 1998. They are still good, and I have ran a best of 1.27 60ft. Just felt I was leaving something on the table in regards to tuning, since they are 5 way adjustable single action.
The only shocks made for rear that are good quality DA are made by Strange, however after I have used the fronts made by Mark Menscer, you get what you pay for. I only had to change settings from his set 2 clicks for my application. Custom made tuned shock. The stock shocks are pin and pin, and his shocks are based off AFCOs, they do not make that style, so I custom made my own set up. I used an AFCO lower mount, and it fit perfectly on the Cal Trac mounting bracket. I welded it on and they fit like a glove. Now see about getting into the 1.25 60 ft......Stay tuned....DragBoss
Logged
408 Cleveland, 9.69 at 136mph with a 1.27 60 ft. Just starting to fine tune.
my63
Hero Member
Offline Offline
Defending myself from the DLWM crowd
« Reply #1 on: September 10, 2015, 06:42:36 PM »
I did something similar except mounted mine upside down as it was almost impossible to reach the adjuster on the stud in the trunk.
I made my own upper stud conversion mounts with a fairly wide range of mis-alignment allowed. This way I can reach both adjusters easily without crawling into the trunk.
Logged
1963 Fairlane Bracket Car, 408", C-4, Canfields, Vic Jr. E-85
Thanks to: Mark Sullens, www.marksullense85carburetors.com www.rebco-machine.com
DragBoss
Sr. Member
Offline Offline
« Reply #2 on: September 10, 2015, 07:22:49 PM »
My63,
I was thinking that too, but was dying to get them in there before season over. Luckily, I can climb in there easy and adjust with no prob, but your right does suck...any pics?
Logged
my63
Hero Member
Offline Offline
« Reply #3 on: September 11, 2015, 05:53:22 PM »
No shock pics as of now, but I can get you some this weekend.
My mounts are rather crudely made, more function that form! These were before painting. I used misalignment washers to center the shocks.
The adjuster is still up high, but I can crawl quickly under the car and make both adjustments.
Logged
DragBoss
Sr. Member
Offline Offline
« Reply #4 on: September 11, 2015, 09:00:53 PM »
They look good, I would be interested in pic of shock if you have time. Thanks
Logged
289nate
Hero Member
Offline Offline
« Reply #5 on: September 12, 2015, 08:36:29 AM »
That's cool.
Logged
FomocoBw
Hero Member
Offline Offline
So I'm an "asshole" is that a Bad thing?
« Reply #6 on: September 12, 2015, 09:23:27 AM »
Tim
Tape up the spanner nut threads from debris damage for future use as a coil over. I used a strange dual adjustable for several years on the leaf spring setup... Unwrapped the tape I put on them and they look like the day I put them on. 😁
Logged
Just 'Cuz your "college" educated does NOT make you SMART!...
Ya, Its and Iron 4v head, Stock Iron Block Cleveland thats F@#k'n fast
Real race cars have THREE pedals.
"Life's tough,Pilgrim,it's tougher when you're stupid" ---The Duke
9.93@134+ 1.38 '60 best. 9" slick, single 4 no power adder.
DragBoss
Sr. Member
Offline Offline
« Reply #7 on: September 12, 2015, 03:17:51 PM »
Tim
Good advice Bruce, will do.  Get that bad ass mustang done yet?
Logged
my63
Hero Member
Offline Offline
« Reply #8 on: September 12, 2015, 05:36:09 PM »
I'll get some tomorrow after church for you.
Logged
my63
Hero Member
Offline Offline
« Reply #9 on: September 12, 2015, 05:37:03 PM »
Or after football, or maybe tonight after the movie is over, lol
Logged
DragBoss
Sr. Member
Offline Offline
« Reply #10 on: September 12, 2015, 08:28:17 PM »
No hurry, working all weekend, enjoy your time off
Logged
my63
Hero Member
Offline Offline
« Reply #11 on: September 13, 2015, 10:08:29 AM »
Here are some photos of the lower mount from different angles:
Logged
my63
Hero Member
Offline Offline
« Reply #12 on: September 13, 2015, 10:11:16 AM »
And the upper mount:
Logged
my63
Hero Member
Offline Offline
« Reply #13 on: September 13, 2015, 10:21:23 AM »
Afco doesn't make a shock for our car as you mentioned. Not sure what Mark used for yours, but these, based off of measurements, are front shocks off of a Plymouth Belvedere.
I even have Belvedere shocks on the front of the car!
If you're looking for any other detail or angle, let me know.
Logged
DragBoss
Sr. Member
Offline Offline
« Reply #14 on: September 14, 2015, 10:34:43 AM »
Thanks for the pics, good job. Not sure what shocks he used, but this gives others ideas if they want to good DA on rear, can,t wait to test. Be nice to get a 1.25 60ft, put me in the 9.50s....DragBoss
Logged
Pages: [1] Print
« previous next »
Powered by MySQL Powered by PHP Powered by SMF 2.0 RC5 | SMF © 2006–2011, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
